RCU Forums - View Single Post - T-34/85 Winter version with DX5e
Old 03-13-2009 | 01:13 AM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: T-34/85 Winter version with DX5e
ORIGINAL: bowlman
Hi Phil changed my mine took a old pill bottle and cut it down to size with a dremel cutting wheel for the rear cover if you do this gearbox replacement make shore if you drill and tap the shaft that its level same with the T-34 wheel pins off just a little and the wheel will wobble .
Thanks Jimmy
Cool Jimmy,
You get that painted and it will be fine, looks great, and thanks for the tips!
The Blitz
RCTankWars.com
