Tuning with velosity stack
You may have pointed the stack into the airflow, don't, you do NOT want ram air. If the velocity stack is inside a cowl, you may have to experiment a bit to get it oriented for best results as the air flow inside the cowl is often not as you expect it to be. If the stack is oriented properly, there should be no change required in needle settings for best results.
