ORIGINAL: wzak29
It’s the 3rd one from the wing center (second in from the tip) the rest are fine. I wish someone tolled me to watch for this I read everything I could find about installing ca hinges and there was nothing about this?
It isn't very easy to buckle a CA Hinge. Considering the hard flexible plastic is in the middle. With the hinge having support on either side from the other hinges I would think it will be OK. Definitely not the most desirable way for installation that is for sure.
As far as telling you about this. Good luck with getting all the information. The great hobby is nothing but learning. Good luck with your hinge.
