RCU Forums - View Single Post - Nascada wheel alignment
Old 03-13-2009 | 03:38 PM
bluferbl
Default RE: Nascada wheel alignment
Wellllllll...seeing as you're the best source...could you explain (briefly will be fine) what the linkage adjustments do.
There's two upper ones at the front.
Two lower ones at the front (are these purely for adjusting the left/right direction of the wheel?)
Two upper ones at the back.
Are there any other common tweaks that would be good to know about?
Thanks.
