RCU Forums - View Single Post - COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Old 03-13-2009 | 07:19 PM
  #393
samparfitt
My Feedback: (43)
Default RE: COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Barry,
thanks.
The 'big dogs' are much easier to add 'stuff' and without adding excessive weight.
Nav lights (cont)
With the nav lights in the wings tips and routed to the inside edge of each outer wing: we need to make up the rest of the electrical system. I made a very large Y (green/black wires) extension with the two top ends of the Y going to each end of the center wing and the bottom end of the Y going to the fuse. There's two female plugs at the top end and a male connection at the bottom end of the Y.
A 2' extension (red/black wires) connects the center wing to the battery case in the fuse.
pic 1:
The two sets of extensions to get 'juice' from the battery case to the nav lights.
pic 2:
nav light battery case screwed to the receiver tray: One wire is routed to the on/off switch on the service panel.
(still got to organize that rats nest!)
ID:	1157106   Click image for larger version
