RE: Inverted Engine
Okay, Lowered the fuel tank tonight, cut the about a 1/4 inch out of the bottom of the balsa that the fuel tank used to set in. The aligment looks 100 % better. Plan on re wrapping it in foam tomorrow and maybe being ready to fly by Sunday. Still need to run the receiver wire back through the fuse to the tail section. I think this will work. i also changed the fuel tank plug, Now have metal tubing. The vent tube runs up with a slight S and the fill tube runs down at a 45 angle. Clunk and clunk line look good too.
