RCU Forums - View Single Post - control surface beveling question
Old 03-14-2009 | 07:43 AM
rainedave's Avatar
rainedave
Default RE: control surface beveling question
I have simply glued triangle stock onto LE's before and it works fine. But, most of the time I use a small razor plane. If you have a router stand for your Dremel you can use a chamfer bit in it.
David
