As Ken mentioned the manufacturers numbers are sometimes... well, manufactured. I tend to look at what size prop the engine can use and maybey what RPM range it spins that prop. If you look in these forums you can find "independant studies" where our fellow modelers with reletive scientific accuracy have tested many of the commonly used engines with various props and posted the resulting numbers. I tend to trust these independant researches a little more
