RE: H.P.
I agree on the manufacturers specs, i usually go down to the "tachometer readings" forum in the engine section and look at prop/rpm numbers for a given engine as go from there. I also use the ThrustHP calculator to plug in the prop/rpm numbers to give me an idea if a certain engine will perform the way i need it on a certain plane.
