ORIGINAL: Stickbuilder
A couple of things come to mind. I need to preface this by saying that I am not trying to talk down to anyone, but am basing the comments on 60 years of building and flying model aircraft.
1. Regardless of your starting method, make sure that there is someone nearby, so that if the unexpected happens, you have help.
2. Never apply starting energy to a model engine unless you intend it to start. Flipping a hot, wet engine can cause ignition, even if there is no glow ignitor attached to the plug (I know it's rare, but it has happened).
3. If one is available, always use an electric starter instead of flipping the prop with your hand, or a stick.
4. Always have a helper to restrain the model when you are starting the engine.
5. Never reach over a running prop to make any adjustment, or to remove the glow ignitor.
6. Never start an engine when bystanders are within the arc of the prop.
7. Have as much (or more) fun with the hobby as I have.
8. Don't wear loose clothing when starting an engine (especially unbuttoned sleeves).
Bill, AMA 4720
Waco Brother #1
Number 5 Don't ask how I know but it only take a second for something to go wrong. It only take a small distraction and OOOPs there goes a finger!!!!
