ORIGINAL: KC36330
ORIGINAL: Pete737
do you have yto use a UAT with a test rig setup? whats the usual tank config for running on the bench?
Pete
not at all, the only fuel system i use for bench running is i hook my start up/taxi tank directly to the fuel pump.
i can't help but notice in all the above posted pics none have a FOD guard, myself i won't run a turbine at all (on the bench or in a jet) without one.
Good advice!! Not only for loose stuff on the bench, but also good for keeping all your fingers.
