RCU Forums - View Single Post - Install of hinges
Old 03-15-2009 | 07:00 AM
mclina's Avatar
mclina
Default RE: Install of hinges
ORIGINAL: KitBuilder
Has anyone tried the hinge points.. Im using them for the first time because I like to try new things with each build. They were easy to get setup and look real nice.. howeer. .after covering... im concerend about getting the expoxy down into the hole and not on the hinge pin, etc itself. Has anyone used these before. This is where I'm at pre-covering.
I prefer the Hinge Points as well. I use the hinge glue, which has tip that lets you inject the glue into the hole. If I were using epoxy, I'd try to get a syringe or something to shoot the glue into the holes.
Good luck
