RCU Forums - View Single Post - am i lucky, or does this happen all the time
Old 03-15-2009 | 07:25 AM
Rodney
Default RE: am i lucky, or does this happen all the time
Most engines will run fine without mufflers. It wasn't to many years ago when few if any of the model engines had mufflers. When noise levels started to be a problem in keeping flying fields (about the mid 1950's) mufflers started to become more common. Some engines then used baffles on the exhaust to help with setting up engine idle speeds.
