RE: Another MaxCat built but only 48"
I am going to run my pipe partially inside. I am using a 90° header and going to exit the pipe in an angle slightly pointing upwards. I will show you in upcoming pictures. I also need to put an end muffler on my pipe to quite it down some. There is no way to hide the entire exhaust inside the hull. But that's O.K. since the cat is only 48" long.
