RCU Forums - View Single Post - Running without prop
Old 03-15-2009 | 11:31 AM
j.duncker's Avatar
j.duncker
Default RE: Running without prop
Put a flywheel on it and start it on low throttle. Providing you do not over rev it you will have no problem BUT it will overheat if there is a significant amount fuel being used. approx 80% of fuel is turned into waste heat. Some sort of fan cooling would be needed for extended runs. 30 - 60 seconds no problem,
Millions of model car engines can not be wrong!
