RCU Forums - View Single Post - EQ-10 Set up
Thread: EQ-10 Set up
Old 03-15-2009 | 01:25 PM
billd3's Avatar
billd3
My Feedback: (8)
Default RE: EQ-10 Set up
ORIGINAL: rrritchey
Hi,
Did you split your ailerons using "Flaperon"? If so, the ailerons are controlled by two inputs. First is your stick for the true aileron part. Second is the flap input, on your transmitter this is a 3-position toggle. In the Flaperon menu you can adjust the flap contribution to the ailerons. You need to "zero" this contribution. I cannot give you the detail on how to do this on the 9303 though.
Yes, They're split...Right off the bat, I don't recall this feature...The only reference to the Flap on the Wing Type page is at the bottom , referencing "Mate" and "Trim" which are inhibited...I suspect that this feature refers to the "flap trim", if and when the ailerons are also to be used as flaps. Since I don't do that on anything I fly, I just turn it all off in the "Device Selection" mode which transfers over to "wing Type"...I think/guess[sm=confused_smile.gif]. To further confuse the issue[sm=confused_smile.gif], I did make sure the flap and Aux trims are set at neutral...Oh Well...Life is good. Thanks again Robert!
