RE: painting Sea Queen.
If your using airplane plywood is good.. put two coats of epoxy over the hull and sand and prime it.. Then paint&clear it,then your fine.Dont add glass cloth because your adding more weight and thats no good..This is no different then race boats,scales hydros..They use 1/16 ply on the skins and brush or spray two-three coats of epoxy on the hulls.. Then sand them smooth fill in any voids&pin holes and prime it sand to paint&clear then your done..
