RCU Forums - View Single Post - needle valve extension
Old 03-15-2009 | 10:38 PM
TakingFlight96
Default RE: needle valve extension
Another way I've seen done is to cut down a T-pin and insert it into needle valve, being held by set screw and simply slot a wooden dowl to go through a 1/4 inch hole through cowel to adjust. The only problem with this is not misplacing the dowel when your not using it. Hope this helps.
TF96
