ORIGINAL: sportster64
Question: when making a copy of a plane and changing propellors from a 2-blade to a 3-blade, should the model show a 3-blade ? I still see a 2-blade propeller ?
No. That can be (or could be) changed in the graphics source TGA's. Somewhere in the past few pages was talk of changing plane paint schemes. I've tried fiddling with the propeller graphics. Never quite got it sorted out.
But for example, if on the Alpha40 or PTS P51, if you change from the 3 blade trainer prop to 11x6, you should notice the extra kick in acceleration, speed and easier gliding. Btw that particular three blade (on the Alpha, F22 and PTS P51 ) is a really different animal fyi in case you weren't aware. The PTS props are really different (should state that within fsone).
