RE: Another MaxCat built but only 48"
Hi Alex,
You guys run very different pipes in the US then we here in Europe. here all muflers are integrated because of noise limits.
I have a 90degree header and pipe just fits in the sponson, WTS will leave you much more room, but your Cat is much smaller..
In your case I would go for a 105 header and stick it out the back.
WTS in the sponson might be an option if you use a pipe without mufler, else I think 105 header will look better.
Keep up the work!
Marcel
