ORIGINAL: MaxCorvette
Hi Alex,
You guys run very different pipes in the US then we here in Europe. here all muflers are integrated because of noise limits.
I have a 90degree header and pipe just fits in the sponson, WTS will leave you much more room, but your Cat is much smaller..
In your case I would go for a 105 header and stick it out the back.
WTS in the sponson might be an option if you use a pipe without mufler, else I think 105 header will look better.
Keep up the work!
Marcel
Did I say 90° header?[sm=50_50.gif]. I was wrong, I meant a 105° header, of course, like you mentioned, Marcel. As soon as I have the deck on I place the motor inside and take a picture. I could also do it like Steve shows it in his post, but I need to stick an end muffler on and that wouldn't look good.
