RCU Forums - View Single Post - esc size
Thread: esc size
Old 03-16-2009 | 11:36 AM
Tony Fitzpatrick
Default RE: esc size
Rye,did I say I have no concern on the esc but then made a remark on the battery? I now see the shape of the hull. [X(]
Two things.....
You have not mentioned what radio set you will use.I know what will happen if you pick up a "full reverse"
I've built a few pt boats in various scales and hull shapes.I've sailed them with different batteries.I'll eat my hat if that boat gets up on a plane with a 12volt-7Ah battery.If you direct drive suitable props for the 700bb the boat will point up at 45 degrees and draw upwards of 30 amp per motor.
Tony Fitzpatrick
