RE: On Off switch setup ??
I just cut an appropriate length of fuel tubing, sliced it down the side, and intend on using it as a safeguard so that the switch does not accidentally get pushed in while in use. You could do it the other way, and use the safeguard so the switch does not get pushed in while in storage. Next is to devise a way to attach it to the plane so it's always around when I need it.
