RCU Forums - View Single Post - ABC internal failure
Old 06-13-2003 | 01:58 PM
DarZeelon's Avatar
DarZeelon
Default Garbage in your engine
Majortom,
This is one instance when you need to exercise your warranty.
Just take your engine to the LHS, or whoever sold it to you and get a replacement free of charge.
I have seen all kinds of machining junk inside an engine, which will make your engine very old, before the break-in is even through.
Just so you don't trash the replacement as well, remove the head and the backplate, just before mounting your engine on the test stand for break-in. Wash it out with methanol and verify no particle, aluminium, steel, brass, or chrome is in the engine.
Oil and reassemble the engine properly and perform the break-in in accordance with this thread:
http://www.rcuniverse.com/showthread...59&forumid=145
Sincerely,,
