RCU Forums - View Single Post - On Off switch setup ??
Old 03-16-2009 | 05:25 PM
Mode One
Default RE: On Off switch setup ??
In for off, let go of the plane while it's idling and check for control surface movement. This verifys that the switch hasn't been bumped to off. I lost a day of flying the other way, because I had it pushed in for on and when I put the plane in it's cradle, it got turned on and used up the battery. I changed to the in for off and have never had a problem.
Again this is one of those "what ever make the most sense to you" things,
