RCU Forums - View Single Post - AVRO ARROW
Thread: AVRO ARROW
Old 03-16-2009 | 07:46 PM
Mike Emilio
Default RE: AVRO ARROW
The target was for 5 Arrows, stand-off scale. I've made 3 fuselages already.
7 formers have been developed specifically for turbine.
Templates have been worked out for the fin.
The 11 foot fuselage is comming in at 7 1/2 pounds.
It's 14" wide, and about 8" high at the sides.
Sandro Novelli is the turbine expert fitting it up.
Peter Eicas from Altecare, is putting together the landing gear package using Behotec stuff.
Got a 20" thick block of foam to make up the wings.
I'm starting on figuring out the templates for the wing.
That foam block is rough cut about 2" oversize. Gives you an idea just how big this wing is. About a 60" chord at the fuse.
ID:	1159505   Click image for larger version
ID:	1159506   Click image for larger version
ID:	1159507   Click image for larger version
ID:	1159508   Click image for larger version
ID:	1159509   Click image for larger version
ID:	1159510   Click image for larger version
flyncrazy (10-07-2020)
