RE: CMPro T-34 Build
thanks guys,did anyone have to extend the motor mounts out from the firewall or did you mount the engine at the very end of the mount? i measured how fari would have to mount the engineon the mountand there is very little material between the bolt and the end of the mount. i was thinking of mounting some blocks to the firewll then the mounts, thoughts? i was gonna use a os46 but i also mounted a saito 56 with the same results. mark
