ORIGINAL: CGRetired
I really prefer the flat slide switches that mount on the outside of the aircraft. I set them up so that pushing them towards the rear of the aircraft turns the power on. Being flat, they can't be turned on or off by bumping or brushing the fuselage. I also use Voltwatch and put it in a visible location so that a quick glance, lit LED's mean the power is on.
And, before taking off, wagging the ailerons to verify that it is indeed turned on..
helps too..
CGr
120% agrement with this. My first planes had the push pull switches, I turned them on putting them in the car, I turned them off bumping them on the flight line after changing over from the first problem. I finally just mount the switch in the side of the fuselage and also mount a charging jack. Besides not being able to bump on or off, it just gives you a bunch more room inside the fuselage.
Don
