RE: When are glow plugs shot?
Basically, if you haven't deciphered it out of the discriptions so far, when a plug is starting to go bad, you will notice it at idle first. If you listen closely, a new plug will not drop rpms at idle. It may run good for a while longer, so be ready to swap it out. Running lean will also shorten a glow plug's life because of the extra heat.
