Well, if you are at our field, it will roll across the runway, and hit some gopher holes and quit. If the switch gets turned off, it is likely that you are still at idle and probably the controls are neutral and at worst, it is going to slowly roll away when you release it, or just set there depending on your idle. Oh yes, your face will turn red and there will be hoots and hollers from the pits.
Don
