RCU Forums - View Single Post - Balancing a pusher?
Old 03-17-2009 | 02:52 AM
abufletcher's Avatar
abufletcher
Default RE: Balancing a pusher?
ORIGINAL: TFF
Do like this guy and make one http://www.rcscalebuilder.com/forum/...077&PN=2&TPN=6
It is one of the hardest thing to make work, models or full. How much of an extension do you think is needed?
I've seen a stunning 1/3 scale DH2 from some modeler in the UK (Ian?) which used both a drive shaft and, I believe, a reduction system so that it can used a scale size prop spinning a dummy at scale speeds. That wouldn't be needed with the FE2b but I think I'd need an extension of at least 3-5 inches.
