RE: Uniflow fuel tank set-up
The Uniflow set up will not help you draw fuel from a distance. Case pressure is not a good idea either. What you need to get is a cline regulator and use case pressure with that. Case pressure or one way checks provide way too much pressure to the tank and you will not have good mixture through different throttle settings. Track down the cline and that will solve your problem.
