RCU Forums - View Single Post - will it hurt?
Old 03-18-2009 | 01:11 AM
quietnas1
Default RE: will it hurt?
Oh yeah if you use the Carb cleaner from any auto parts store make sure you remove the motor first. Its great on the engine but if it gets on any of the plastic parts on your car it could meke them dry and brittle. Forgot to mention that in the beginig. Also use a zip tie to keep your air cleaner on. I tighten it just enough to were I can barely slide it on the carb. But once it is on it will not fall off.
