RE: Seagull Ultimate 46 Wing Incidence
I have it balanced at 11 cm and it flies great. The ailerons already come pre-drilled for the connectors between the top and bottom ailerons, but make sure that the dinstance from the hinge line is the same. Top and bottom ailerons should move at the same rate.
