ORIGINAL: rye
how would i water cool this esc what do you think ,thanks rye
Hi Rye,
I've added a couple of pictures of the ESC's interior; the Fets are all in one plane, so adding a cooler, like the custom made one in the pics, should not be a problem. Leave the housing off and use shrinktube to hold the cooler in place.
I have no hull available to test the ESC with two, let alone one 700 Neodym on 12V, but I can mount an 8" airscrew on a 700 Neodym and see what the ampdraw is and if the ESC will cut out under load.
Regards, Jan.
