RCU Forums - View Single Post - Fasst antenna placement in a SSE
Old 03-18-2009 | 04:06 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Fasst antenna placement in a SSE
ORIGINAL: nedyob
Hello Minnflyer
Great looking pictures, but one question tho, on the middle and far right picture. Does it matter that the to antenna wire are close to one another, will it cause a problem of any kind?
NEDYOB
The antenna portion of those wires needs to be at least 1/2" apart. The gray wire is not the antenna itself. At the end of each wire is an approximately 1" clear plastic "tip". This tip is the actual antenna and these are what need to seperate. The farther apart you can get these the better off you will be.
Ken
