RE: Bought a used 40 sized P-51 has issues.....
Well at first it was all the way out. It did not have a lot of throw at all, little more then a half maybe 5/8 each way.
So I moved 2 holes closer to increase the throws just to see if it made a diff, it did it just bounces harder...
I applied pressure to the servo it does not give a bit so it is not stripped or failing once its in position it is there to stay.
It does this even in a light banked turn. My first thought was the servo was junk..
