RE: Beat On 30
Ihncheol
I appreciate your offer to take some pictures when you have a chance. You mentioned the need to use a pipe on a 2c 32 which is what I planned on doing if possible. The other option would be to set it up for electric - again, if it makes sense.
I'd like to see if the design is essentially a miniature version of some current F3A designs with a removable belly pan running the length of the fuse bottom from the wing TE to the firewall. In other words, whether the engine is intended to be mounted inverted with the pipe running concealed along the bottom center of the wing. It looks like the wing is one piece rather than plug-in and I see what looks like a belly pan on the wing but I just can't tell whether it's only partial (wing chord) or full (chord plus fuse front).
David.
