RCU Forums - View Single Post - tractor prop efficiency vs. pusher prop efficiency?
Old 03-18-2009 | 11:12 PM
larrysogla
Default tractor prop efficiency vs. pusher prop efficiency?
I read in one of these RC forums that the tractor prop is more efficient than a pusher prop with the same diameter, pitch, prop design, prop material and RPM. Is this true? If it is true, why? If the opposite is true, meaning that pusher are more efficient...then Why also? Thanks for your valuable reply.
larry
