ORIGINAL: lousyflyer
What's the easiest/best/safest/smartest/dumbest way to remove a stubborn thrust/drive washer from a TeeDee .09 so I can change the black plastic body housing?
It's rumored that Harbor Freight sells an inexpensive puller. I would heat up the hub on your gas stove or with a propane torch, slip an open end wrench under the hub and with the prop screw fully threaded in the crankshaft give it a gentle rap with a plastic or wooden mallet.
Bill
