RCU Forums - View Single Post - TeeDee Thrust washer removal
Old 03-19-2009 | 03:58 AM
vauxhall
Default RE: TeeDee Thrust washer removal
Looks to be the same as the .051 method. Remove the head, cylinder, piston and rod assembly, remove the back plate. Put an old prop screw into the crank, stand the crankcase on a piece of flat wood and gently tap the prop screw downwards. The crank should slide right through.
