RCU Forums - View Single Post - Difference between Rabbit VT 90 and Merlin 90???
Old 03-19-2009 | 07:28 AM
jetnuno
Default RE: Difference between Rabbit VT 90 and Merlin 90???
Hi
To my knowledge there is a joint venture between these 2 companies. I own a Merlin 90 that i'll fire it up this weekend.
From the turbine wheel, you can clearly see that the casting is Jets-Munt. I believe the internals should share many mechanical components.
The specs are pretty much the same. Also the cables from the Merlin starter motor come from the inside along with the rpm sensor and in the Rabbit come from the motor.
Electronics are both made by Gaspar Espiell from jets Munt.
There is a test in this month RCJI and I am very confident that this is a great turbine and that I won't regret the fact that I changed it by a P60 in the F16. All in all you can get 95N thrust from a 1Kg weight turbine. That's impressive....
I'll let you know more details when I ran it.
I just regret the fact that the rpm and temp cables are integrated in the turbine and don't have an external cable. That way if you need to take it out of the plane you have to unroot these cables from the frame
Either one you'll choose you'll be ok
Regards
Nuno
