RE: TeeDee Thrust washer removal
If you can find a pully puller that has enough span, reach and has jaws that will fit in the small space afforded by the notches in the collar then you would have the best tool for the job. Good luck with that.
Another thought is that any phenolic thrust washer that can be crushed by the slight pressure need for removal of the drive washer needed to be replaced with a new one anyway.
Robert
