RCU Forums - View Single Post - Echo BME twin
Old 03-19-2009 | 10:46 PM
  #350
buck1856's Avatar
buck1856
My Feedback: (49)
Default RE: Echo BME twin
OK,heres what i did tonight after dinner.I recieved my reed from the stihl chain sawO19.There about 15-20 dollars.No problem getting.
The parts are going on in order from left to right.
The aluminum plate im using is to bolt one of the reed block screws to it and the other bolt will go through both plates and into the corner of the BME case.
The G10 board is my heat dam.
You can also see i recessed where the screw that holds the reed plate on is counter sunk so if it ever comes loose it cant come out at all and fall into engine.
The reason the aluminum plate has the honeycomb holes in it is also to keep stuff from going internally to the engine.I also thought,maybe,it might act as a gas.air seperator.Meaning that the fuel droplets might hit this and become smaller as more of a mist and be a better mixture.
Now im not sure if this will also cause some puddling.
I am using a WT-414,13.49mm.Also this carb has the long throttle and choke rods for easy hookup with a nose gear steering rod.Im going to go take a few more pics of the carb and post a link to the description of this high speed circuit.
ID:	1161672   Click image for larger version
