RE: Building a Dynaflite Super Decathlon
Well Stevo..... I thought by your posts, I was really just tearing along in front of you on mine.... but it looks like you've done at least as many mods as I have although completely different ones. I like your door. I like your double floor system. Very nice and neat. I think I might be seeing a hs 55 in the back there that might be running a contact switch? Is that your light switch? I've been moaning on if I should use a power expander or not. I REALLY like those and am leaning towards doing it. With the gasser, the optical cutoff is a very nice insurance against any potential of ignition feedback into the radio system. Mine will likely get one.
If I'm counting correctly... did you extend your ailerons one extra bay? If so, I've heard this is a very good idea. Mine with flaps and my plan to do full span aileron programming should give me whatever I want for a reasonable roll rate.
Nice Stevo... you've been working every bit as hard as I have and I think have pulled ahead of me again. Very nice work.
