RE: HPI Baja 1/5 Baja 5B SS Kit
I ran my 5B SS for the first time today in the yard. Not a really good place all most too small for 1/8. We have 1/2 acre but with trees house bushes and so on not the best place. Ran about 1 1/2 tanks through it. Need a bigger space to really adjust the HSN. Hope to take it to the track next Saturday to play around.
I still not sure what exhuast I am going to run and right now running the stock can. Here is a list of hop ups I have not some not installed yet as noted.
HPI Baja 5B SS Kit
Team Associated throttle brake
DS1015 servo
Turtle Racing
Complete Clutch System (Orange)
Turtle Racing
HD Tranny Plate (Orange)
Threshold
Shock Umbrella Seals with installation tool
Turtle Racing
Heavy Duty Front Chassis Brace
HPI
Front tire molded foams
washers for e clip conversion
Fast Eddie
Wheel Shim Kit
Scorpion Chassis Brace Satin
Pro-Match 6v 4200mAh Hump Receiver Battery
FF Front/Side Windows Smoked
Modified Pico Failsafe / Soldered Kill Switch Combo
Bad Horise Shock Covers
Heavy Duty 20T Drive Gear (Will not install till I have the other gears)
Outerwares pull starter cover
PhatDad Fan Cover Saver
Nomadio RX
ADA RC Intake Manifold - ORANGE (not installed yet and will do during phase 2)
Quick Release Roll Cage Tubes
HPI Heavy-Duty Idle Gear 30 Tooth
(One more gear and I will install all 3)
Pro-line Bow-Tie Rear Tire Set With Blue Foam Inserts
.020" (0.50mm) Copper Cylinder Gasket
(Will install during phase 3 when I hop up engine)
Hostile Mini MX Tire Soft
