ORIGINAL: marc s
Guillermo
Can you send me the pictures you upload in the units to start the slide show? Are those .jpg images?
I am still working on the images, most of which can from Pilatus in Switzerland, a very helpful company
Once I have made more progress I will drop you a PM.
Bela the unit is 2.4" digital photo frame, pic attached of the unit box and the wiring so far. Red/Black are the battery feeds which are nice and easy, the White/Black are the conection
to the contact switch which are very tricky to solder, infact all this was done by Rich a friend who has access to some very fine soldering equipment!
Will work on the cockpit frames today and will post any progress.
marcs
Thanks Marcs
Meanwhile, I will be looking for MFD pictures on the web
Finally I decided to get two uOLED-96-G1 displays for my project because of the screen size (0.96" diagonal or 20mm x 14 mm active display area) and the prices came down from USD $ 79.95 to USD $ 46 each. Although I think I can fit the Coby 1.5" displays, I prefer to try with the uOLED despite their cost.
Here are the links:
http://www.4dsystems.com.au/prod.php?id=9
http://www.4dsystems.com.au/download...ual_Rev1.0.pdf
http://www.4dsystems.com.au/developers/
Guillermo
