RCU Forums - View Single Post - BME 115 Performance
Old 03-22-2009 | 10:19 AM
altavillan
Default RE: BME 115 Performance
Yes, But it's a SD Katana. Find a 115/116 and don't look back. I have a plastic reed block from The new owners and it looks like it will do the trick. If you find one there's a couple things I suggest doing like adding the AI snorkel and re-locating the diaphram vent tube to where mine is. And adding a very tiny hole to transfer puddled fuel back into the flow. Toss the head gasket so the lower ring doesn't travel so low it digs into the intake bridge. Thats about all I did to mine, other than the home made reed block stuffings.
The Katana goes up like a missle and you can blip the throttle and rip any time you want.
