RCU Forums - View Single Post - Learjet .40 Build
Old 03-22-2009 | 04:53 PM
  #252
Props4ever
Default RE: Learjet .40 Build
ORIGINAL: brenthampton79
also sam im pretty bull headed so once i decide to do this i won't back away from the edf thing i may have edf's on there the size of the good year blimp but I'll try to make it work. to be honest thats the only reason i bought the lear is to try the electric edf on it.
well any ideas you have i would appreciate it
Hey no problem there Brant, go ahead and do it, make sure you post on here and we will be watching your experiment. If you succeed then we will follow you but it if it failed then least you also tried it.
I have a feeling these dummy nacelles are bit smaller in size if i were to scale them down, so if that's the case then i will make newer bigger ones and mold them also as i plan to do with cowl of these planes. So there you go maybe your 90mm fan will fit in newer nacelles who knows...hehe
