RE: Jetcat Kero problem!
Interesting information........
I'm planning to buy a JetCat P160SX turbine with Kero start and is good to know about the possible problems.
I normally use Duralite 4300 mah batteries and if this is not enough, I can always use 5200 mah Fromeco's.
I guess the 13AWG connector is preferred over the typical Multiplez connector and that is a good thing to know. Maybe I should upgrade my other planes too.
Are the supplied cables good enough for the Kero start application or should I plan to change them ?
